Avant 32 upgrade
This post has 3 Replies | 3 Followers
delite
Posts 2
Silver Member
delite Posted: Thu, Nov 18 2021 9:23 PM
Hi
I'm in the progress of rebuilding my Avant 32 television in the following way. Stripping it regarding picture tube and corresponding electronics to replace the picture tube with a flat screen from (sorry) Philips. The philosophy is obviously to upgrade the image quality, avoid sound distortion from image interference and of course maintain the sound of the Avant 32 beovision. To get along with this I need complete circuit diagrams of the PCBs. Do any of you folks have this dokumentation? My Avant 32 is a type 8430.
Ravsted
Denmark
Posts 345
Ravsted replied on Thu, Nov 25 2021 6:28 PM
Hi
I did something similar with the BV5
I believe the chassis is more or less the same in the two TV's
If you follow the same approach as I did I think you can accomplish this without any diagrams.
Good luck
https://archivedforum2.beoworld.org/forums/p/41909/317632.aspx
Stoobietoo
Exeter, Devon, UK
Posts 692
I am sure that someone has done this. I cannot find the thread now, but it was in a discussion about upgrading the Bevision 5 screen.
Stoobie
delite
Posts 2
Silver Member
delite replied on Sun, Dec 5 2021 6:13 PM
Thanks for your comments/suggestions.
It's right that the Beovision 5 upgrade is a similar case. However, it's not as simple when you want to upgrade from a CRT television.
You need to find out what circuit modifications are needed when the signals to and from the CRT are disturbed;-)
I have asked Bang & Olufsen support to help me. Now I'm waiting for their positive (hopefullly) response...
Page 1 of 1 (4 items) | RSS
