Beovox redline 140/7000 woofer alternative?
This post has 1 Reply | 0 Followers
Stereomensch
Posts 322
Stereomensch Posted: Sun, Jan 23 2022 9:11 PM
by accident I found this video on YouTube.
this guy uses different woofers on his speakers:
https://m.youtube.com/watch?v=dnnVg1z6cQw
He seems to use Fenton 8 Ohm speakers.
probably these ones:
https://www.kaufland.de/product/344374744/
i really don’t if it works.
i just wanted to share it with the community.
regards chris
Dillen
Copenhagen / Denmark
Posts 13,191
Dillen replied on Sun, Jan 23 2022 9:38 PM
That guy seems to know very little about speakers.
Yes, of course they sound better than before. Woofers with their surround missing plays nothing - and at least heavily distorted.
If I remember correctly, the original woofers are 6 ohms impedance, so the balance between the tweeter/midrange and woofers will be off.
But why use inferior drivers like that?
You cannot even look up their T/S parameters. I bet the Vas would be quite high.
Generally, finding modern replacement woofers for what B&O originally used is often impossible, and it's typically (but not only) because they require a much larger cabinet volume. Something the RLs just doesn't have.
Having the original woofers refoam'ed would've be a far better solution in my opinion. They are excellent drivers.
The next owner will wonder if this junk is really what B&O made.
Page 1 of 1 (2 items) | RSS
