Beomaster 8000, one channel distortion at low volume.
This post has 31 Replies | 2 Followers
BO
Halmstad, Sweden
Posts 728
BO Posted: Mon, Aug 18 2014 10:45 AM
Fault located to the power stage (PCB no. 5). Idle current & DC offset adjusted according to service manual.
Distorted sound all low volume, mostly in the low frequencies. At higher volume (over 3.8) there no audible distortion.
Where to start look? I'm thinking input cap C200 or TR201/202.
Ideas?
//Bo.
A long list...
Dillen
Copenhagen / Denmark
Posts 13,191
Dillen replied on Mon, Aug 18 2014 10:56 AM
Capacitors ?
BO
Halmstad, Sweden
Posts 728
BO replied on Mon, Aug 18 2014 2:58 PM
OK, I now recapped the board, found some bad caps. Readjusted Offset and Idle current.
Still same problem with distorted low volume.
//Bo.
A long list...
sonavor
Texas, United States
Posts 3,732
sonavor replied on Mon, Aug 18 2014 3:09 PM
Is the distortion there coming out of the preamp board?
-sonavor
BO
Halmstad, Sweden
Posts 728
BO replied on Mon, Aug 18 2014 3:21 PM
No, signal from PCB3 and PCB4 is undistorted.
//Bo.
A long list...
Dillen
Posts 13,191
Dillen replied on Mon, Aug 18 2014 3:43 PM
Speaker switches... Is the distortion on both speaker sockets ?
Is the distortion also in headphones ?
BO
Halmstad, Sweden
Posts 728
BO replied on Mon, Aug 18 2014 4:24 PM
On both speaker sockets but not in the headphones!
//Bo.
A long list...
BO
Halmstad, Sweden
Posts 728
BO replied on Mon, Aug 18 2014 6:42 PM
Sometimes you look in the wrong placesSmile
It turned out that this little thing was the culprit!
Found out when connecting the speaker directly to the pcb. Since the sound was good in the headphones i suspected the speaker switches, but when the distortion still was present i started to suspect the speaker! Thanks to Martin who put me on the right track
Still have to solve the input-card problem. The TP1 switch is malfunctioning.
The switch keeps the TP1 active on one channel even when not activated, thus stopping the signal from FM/PH/TP2.
Temporary solved by bridging, but then I have no TP1 input.
//Bo.
A long list...
sonavor
Posts 3,732
sonavor replied on Mon, Aug 18 2014 8:53 PM
You haven't found a modern replacement IC switch device?  The control for the switch has to come from the switch panel. Have you checked that the connection from there is working?  I have had some outages with my volume control and FM station dial - those were the result of connections (wire connections) starting to break where the ribbon cable connects to the button panel board. In fact, many of my Beomaster 8000 issues have just been connections.
-sonavor
BO
Halmstad, Sweden
Posts 728
BO replied on Mon, Aug 18 2014 9:03 PM
sonavor:
The same control signal and IC is used for both channels and only one channel have the problem.
There is a possible replacement: AD7512
http://docs-europe.electrocomponents.com/webdocs/077f/0900766b8077fdee.pdf
Alternatively a mechanical relay will do the job.
//Bo.
A long list...
sonavor
Posts 3,732
sonavor replied on Mon, Aug 18 2014 9:42 PM
Mouser carries the AD7511
It is an expensive little device.
BO
Halmstad, Sweden
Posts 728
BO replied on Tue, Aug 19 2014 8:15 AM
I ordered some AD7512DIKN from China. Lets see how it works out, when and if they arrive!
//Bo.
A long list...
chartz
Burgundy, France
Posts 4,171
chartz replied on Tue, Aug 19 2014 8:34 AM
They will be fakes, make no mistake. Oops, too late! Big Smile
Jacques
BO
Halmstad, Sweden
Posts 728
BO replied on Tue, Aug 19 2014 8:44 AM
Maybe or maybe not. I've ordered components from China several times and has not been disappointed so far!
Of course I know there's a risk, but its always a risk buying something on the Internet.
http://www.ebay.com/itm/1X-AD7512DIKN-Protected-Analog-Switches-AD7512-/121017773933?pt=LH_DefaultDomain_0&hash=item1c2d38af6d
//Bo.
A long list...
Søren Mexico
Mexico City
Posts 6,411
BO:
For my solar water heating system I ordered pump and controller from China, 1/10 of the price in the US, And same quality, as most of these items are China made and only has a different brand name attached.
chartz
Burgundy, France
Posts 4,171
chartz replied on Fri, Aug 22 2014 7:34 AM
I meant this particular, unavailable component. I steer clear of miraculous finds like this. But you might be lucky indeed.
Jacques
BO
Halmstad, Sweden
Posts 728
BO replied on Fri, Aug 22 2014 7:46 AM
I wish myself luck, but it's not that difficult to find.
Analog Devices AD7512DIKQ
//Bo.
A long list...
Premiumverum
Netherlands
Posts 115
I tried replacing the switching IC's with relays and it really made a difference, much more detailed/clear sound on my BM8000 +M100 speakers. I am terribly allergic to audiophile upgrade nonsense but I really like the result on this one.
Could be the combination of BM8000+M100 though, I have yet to test how it sounds with the MS150 I just bought but they need recap first.
Maybe the new AD7512 will also have clearer sound than the old IC.
Do you hear a difference in sound with the wire bridge in place?
BO
Halmstad, Sweden
Posts 728
BO replied on Mon, Aug 25 2014 3:44 PM
Premiumverum:
No, I cannot say that I hear any difference. Maybe It will be easier to tell when I have recapped the M100 and the BM8000. Personally I doubt the the switching IC's will affect the sound audible.
//Bo.
A long list...
BO
Halmstad, Sweden
Posts 728
Arrived today. Let's see how it works out.
//Bo.
A long list...
chartz
Burgundy, France
Posts 4,171
chartz replied on Tue, Sep 2 2014 7:20 PM
They look genuine. Smile
Keep one for me! Stick out tongue
Jacques
Dillen
Posts 13,191
Dillen replied on Tue, Sep 2 2014 10:46 PM
chartz:
I don't  know.
I never saw the triangular Analogue Devices logo that big and in front of the rest of the lettering before.
They were always like this http://image.usatradekey.com/usa-on-sale-1029580-AD7512DIKQ.jpg
or had no logo at all.
- But they could be genuine.
BO
Halmstad, Sweden
Posts 728
Success. Its working!
//Bo.
A long list...
BO
Halmstad, Sweden
Posts 728
Nice!
//Bo.
A long list...
chartz
Burgundy, France
Posts 4,171
chartz replied on Thu, Sep 4 2014 4:39 PM
Excellent! Does it sound good then?
Jacques
BO
Halmstad, Sweden
Posts 728
BO replied on Thu, Sep 4 2014 5:39 PM
chartz:
To my ears its sound as good as the temporary bridge I made. In other words, it doesn't color the sound to me, which is good.
//Bo.
A long list...
sonavor
Posts 3,732
sonavor replied on Thu, Sep 4 2014 6:09 PM
Great news. If the new components pass your burn-in tests the supplier could be a good source to go back to.
BO
Halmstad, Sweden
Posts 728
Now the board fully recapped with some upgrades (film caps & "better" OP-amps)
//Bo.
A long list...
sonavor
Posts 3,732
sonavor replied on Fri, Sep 5 2014 7:03 AM
Which op-amps did you replace and what did you replace them with?
-sonavor
RaMaBo
near Munich
Posts 626
RaMaBo replied on Fri, Sep 5 2014 1:20 PM
the old standard chips IC1,3, 5,6,7 and 101 / 201  (LF 353N or TL072CP) were replaced with new, better OPA2132PA (could be seen on the picture).
At least IC 3,5 and 7 but i guess he did all in the signal path.
You can search the forum for OPA 2132 and will find quiet a few threads about changing the original OpAmps against better rated, new ones.
Those OPA 213x are very low noise, high slewrate (good for high freuencies) and direct replacement because of the pinout.
Ralph-Marcus
BO
Halmstad, Sweden
Posts 728
BO replied on Fri, Sep 5 2014 2:55 PM
RaMaBo:
Correct!
//Bo.
A long list...
BO
Halmstad, Sweden
Posts 728
BO replied on Fri, Sep 5 2014 4:15 PM
Correction. Its the OPA2134PA.
//Bo.
A long list...
BO
Halmstad, Sweden
Posts 728
Ideas?
//Bo.
A long list...
Dillen
Posts 13,191
Capacitors ?
BO
Halmstad, Sweden
Posts 728
//Bo.
A long list...
sonavor
Posts 3,732
-sonavor
BO
Halmstad, Sweden
Posts 728
//Bo.
A long list...
Dillen
Posts 13,191
BO
Halmstad, Sweden
Posts 728
//Bo.
A long list...
BO
Halmstad, Sweden
Posts 728
//Bo.
A long list...
sonavor
Posts 3,732
-sonavor
BO
Halmstad, Sweden
Posts 728
sonavor:
//Bo.
A long list...
sonavor
Posts 3,732
BO
Halmstad, Sweden
Posts 728
//Bo.
A long list...
chartz
Burgundy, France
Posts 4,171
Jacques
BO
Halmstad, Sweden
Posts 728
//Bo.
A long list...
Søren Mexico
Mexico City
Posts 6,411
BO:
chartz
Burgundy, France
Posts 4,171
Jacques
BO
Halmstad, Sweden
Posts 728
//Bo.
A long list...
Premiumverum
Netherlands
Posts 115
BO
Halmstad, Sweden
Posts 728
Premiumverum:
//Bo.
A long list...
BO
Halmstad, Sweden
Posts 728
//Bo.
A long list...
chartz
Burgundy, France
Posts 4,171
Jacques
Dillen
Posts 13,191
chartz:
I don't  know.
BO
Halmstad, Sweden
Posts 728
//Bo.
A long list...
BO
Halmstad, Sweden
Posts 728
Nice!
//Bo.
A long list...
chartz
Burgundy, France
Posts 4,171
Jacques
BO
Halmstad, Sweden
Posts 728
chartz:
//Bo.
A long list...
sonavor
Posts 3,732
BO
Halmstad, Sweden
Posts 728
//Bo.
A long list...
sonavor
Posts 3,732
-sonavor
RaMaBo
near Munich
Posts 626
Ralph-Marcus
BO
Halmstad, Sweden
Posts 728
RaMaBo:
Correct!
//Bo.
A long list...
BO
Halmstad, Sweden
Posts 728
//Bo.
A long list...
Page 1 of 1 (32 items) | RSS
