Beogram CDX Only right sound at start and left start after 10-15min
aragorn83
Posts 15
aragorn83 Posted: Fri, Jan 7 2022 3:03 PM
i have a Beogram CDX, i love this player but mine have a little default.
when i play a cd only right sound channel works and after about 10/15 min the left channel  start and after i can listen many cds witthout problem. But wheni din't use it after a fews hours. The same problem reappear.
I start by check visually all composant, i didn't see anything and i try to restore the vias  like i see in this blog : https://beolover.blogspot.com/search/label/BeoGram%20CDX
 the problem is still here.... where can i check more ? what can i do ?
thanks a lot :)
Dillen
Copenhagen / Denmark
Posts 13,191
Dillen replied on Fri, Jan 7 2022 3:33 PM
Common problems:
- The signal cable breaks internally about 5cm from the plugs,
- The muting relay(s), which are of the reed type.
- The capacitors in the analogue circuits, actually on the entire decoder board , have started to give up. I would replace the lot.
aragorn83
Posts 15
aragorn83 replied on Wed, Jan 19 2022 10:35 PM
Thanks,
i check the cable and no problem.
relays was good.
i change capacitors on the decoder board and restore all the vias and now it seem to be good.
Thanks a lot :)
Page 1 of 1 (3 items) | RSS
