So, as I didn’t find a stand for my 10-40, I used the motor stand from my 7-32 which I had swapped already for the table mount. With the BV 10-40 back plate, everything works wonderfully apart from the motor stand which has a DIN plug, the BV10 has an 8 pin Microfit.
And here’s my question:
who knows if it’s possible to change the DIN to a Microfit and where would I get the wiring diagram?
Thanks in advance.
Nick
