Hi all
Looking for some advise regarding a Beo4 mark II controller I've picked up.
Can someone tell me if it is normal for the display screen to remain on all the time (text showing), or should it turn off at some point?
Cheers
Gavyn
Text shows all the time on Beo4s - this doesn't drain the battery. The display only goes off if you take the batteries out and then press a button!
Hope this helps!
Excellent! Thanks very much for responding.
