Dear friends,
I just got my beomaster 7000 today with beolink 1000 remote controller; The normal function is just fine like: volume up and down, next track and previous track, CD, A.TAPE and Radio.
But I do have a question about the radio. I found no way to use my beolink 1000 to tune the FM radio station. According to the beomaster 7000 manual, it looks every deep setting must be use beolink 7000?
Is that possible to make the radio tuning by using beolink 1000? there really does not have many button in beomaster 7000 machine itself.
- For link with beomaster 7000' s CD, speaker, even beogram 7000, I think beolink 1000 is fine.
Any idea?
Thanks!
Daniel
just found your query. And yes there's a solution:
Radio-Goto-up/down-store-number-store-store
This sequence should work.
It can also be extended to key in the frequency directly: See this old thread.
Ralph-Marcus
