Max Volume Settings on Beosound 9000?
This post has 3 Replies | 0 Followers
Ferdinand
Malmö, Sweden
Posts 541
Ferdinand Posted: Sun, Aug 10 2014 5:53 PM
I am familiar with setting start-up volume level but I was wondering if a max volume can be installed as well. I could not find it in the manuals.
My 3yr old just figured out where the volume buttons are on a Beo4 ... that hurted my ears Angry
Yes, another options is not to have her the Beo4 but I can't prevent everything :-)
Killmouski
A hot tin roof in Stockholm
Posts 55
Dont change the world to suit the kid, instead educate.
Millemissen
Flensborg, Denmark
Posts 14,680
If there are certain times, when the 9000 is not used/should not be used, you could set it into Option 0 temporary.
Ferdinand
Malmö, Sweden
Posts 541
Ferdinand replied on Sat, Aug 23 2014 9:27 PM
@ minuscat - so true , an a bit more education of the parent (me) wouldn't hurt either. It's work in progress.
@ millemissen - thanks for the tip
Speaking of education (ahum) ... a nice welcome home 'find' after being away for a day ...
yes, the same 3yr old :-)
Page 1 of 1 (4 items) | RSS
