Hello All
Does anyone have the key combination for Sky HD key conmversions via PUC? I know that select is go twice but what is it on the beo6.
thank you
Eclipse 65V1-32Beosound M5Essence MK2BLI
If the command is 2x GO on an older Beo4, just program a macro with PLAY - PLAY. A delay of at least 100ms might help.
If it`s a new Beo4 (1710) just 2x select with delay.
Stefan
btw: How do I program macros with the Beo 5 or 6?
You can list several actions for one single button in the config tool.
If your favourite TV-channel is "MY HD", and it`s number 123 on the channel list,
create a button named "MY HD" and program in TV mode:
CIFFER_1
CIFFER_2
CIFFER_3
a delay between these commands might help as mentioned before.
Also possible to send a TV command with your favourite channel and activate at the same button a LIGHT scene, maybe LIGHT - TV.
