CDX lid not closing completely
Paul Strong
Totnes, Devon, uk
Posts 15
Paul Strong Posted: Sat, Sep 27 2014 2:51 PM
ive had my CDX a for a month or two now and have a problem that's started today. When the lid closes, it appears completely closed but the light stays on and the disc doesn't spin. A bit of pressure on the lid where the center of the disc is does the trick. Now, it's fitted into a fairly tight space and I put some LED lights in and I can see that they could have prevented the lid fully opening by a fraction. It's the only thing I can think of that's different.
any suggestions would be welcome
thanks
paul
Dave Farr
France
Posts 2,283
Dave Farr replied on Sat, Sep 27 2014 3:29 PM
Paul, move it our from the space it's in and see if it works properly when the lid can fully open.  If it does, you've answered the question.
Dave.
Paul Strong
Totnes, Devon, uk
Posts 15
Thanks for the reply Dave, I've already tried that .... I'm wondering whether the lid itself has bent slightly as the edge goes hard on the surface on the right hand side but not the left, a bit of pressure on the join of the persex and aluminum on the left clicks it into action
Paul Strong
Totnes, Devon, uk
Posts 15
What is the sensor that throws the switch?
chartz
Burgundy, France
Posts 4,171
chartz replied on Sat, Sep 27 2014 5:13 PM
Actually there's an adjustment for this. The procedure is in the service manual.
Jacques
Paul Strong
Totnes, Devon, uk
Posts 15
hii jaques
just looking now, I'm wondering if it's the one through the bottom of the case
chartz
Burgundy, France
Posts 4,171
chartz replied on Sat, Sep 27 2014 6:25 PM
Yes but don't shoot in the dark, you really must respect the manual's procedure (sorry).
Jacques
Paul Strong
Totnes, Devon, uk
Posts 15
Sorry, what do you mean?
Paul Strong
Totnes, Devon, uk
Posts 15
Ah yes I see .... I guess the problem is really that the switch isn't being tripped, ie switching off the light and spinning the disc, so it's whether the adjustment of the lid closing will affect that, it's really only a very small distance involved and there's not much visible that the door hasn't closed. I'm not used to looking at these exploded drawings so not really sure how the lid relates to the switch 😕
Page 1 of 1 (9 items) | RSS
