Dropped the Beo4 onto the floor last night, all works fine and no visible damage (except to the floor!) but some of the clips have broken off the plastic battery cover.
I'd like to get a replacement plastic battery cover, I saw on the archived forum that these were available from dealers for around 5 euro a few years ago, but my local dealer (from whom I bought the TV a couple of months ago) says it will cost GBP 15! Is that really how much they cost now?? I know it's B&O, and seems mad to waste too much time quibbling over GBP 15, but seems a lot for a small piece of plastic!
Try here: http://www.avaservices.co.uk/
Thanks - I'll give them a try. In fact I think it was them that repaired my Century a while back, which is still going strong!
I can send you one for free!
Brengen & Ophalen
That would be very kind, thank you! I'll send you an email!
