Hi everyone,
Can anyone recomend an engineer to do a set up for me in Manchester. I've master linked most of the rooms in the house but need someone to connect everything up and do a set up for me.
Much appriciated in advance.
Adrian
Hi Adrian,
welcome to Beoworld.
Have you contacted B&O in Manchester?
Otherwise, if you explain your system, we may be able to help as there are plenty still using Masterlink and know the 'ins and outs' of it. Where in Manchetser are you? - I lived in Sale most of my younger life.
Dave.
Thanks Dave,
Yeah I tried B&O Manchester but they were extortionate!!
Ok here goes!
Living room - Beovision 7, Beosound 3000
Dining Room - Beolab 3500
Kitchen - Ceiling speaker with the IR eye
Bedroom 1 - Beovision 6
Bedroom 2 - Beovision 6
I have got the passive amp and have run all the cabling to it. I was also provided with some Bluetooth receivers so I could hook up the ipod wirelessly.
Sale is around the corner, I'm from Chorlton!!!
OK. I used to live at number 7 Totnes Road in Chorlton!
I'm not a link expert but that should give some of the link users something to get their teeth into. Is it the option settings you need help with or anything else?
No way!
To be honest I'm not entirely sure. All I know is I've got all of the equipement and it needs hooking up!!!!
Thanks for your help Dave
I've just sent you a pm via email.
Graham
