does anyone have any tips of what can be done to refurbish white LC2 covers that has become yellowish - is there any miracle method?
(except to respray them white)
Best regards,
Riven
My B&O products: Beosound 9000, Beosound 2300, Beosound Century, Beolab 8000, Beolab 6000, Beolab 4000 x2, Beolab 3500, Beolab 2000, Beolab 10, Beolink Active x2, Beotime, Beo5 x2, Beo4, A9 keyring x2, LC2 dimmer x6 and growing....
I've have good experiences with leaving the covers in a solution of water and some chlorine bleach (don't know if that's the correct term - it's the type you would use to clean your bathroom with) over night. After that I simply rinsed them with a good amount of water and then they looked like new again if I remember correctly.
/Dennis
Well I for one never had success with bleach, the things turning yellow again after a few months.
Jacques
Ok, so it have some effect then? Will try soaking it in some bleach this weekend. Have also seen that one can use the same "chemicals" you use to bleach hair.
Amonia or peroxyde. Yes it has some effect, albeit a temporary one.
