Hi all!
There is a thread in the archived forum that discussed this very thing:
http://archivedarchivedforum2.beoworld.org/forums/p/39946/337789.aspx#337789
and yep, I need some of those clips. Where on earth do I find them? The old thread mentions "Martin might have some"???
thanks!!
Hi JamesCrispy!
Did you ever locate this clip?
I need the very exact same thing for my Beogram 2400 dustcover to function properly as one of them has snapped.
Any help locating a clip would be very much appreciated!!!
The shape looks quite easy to make by yourself. Use acrylic for that purpose.
Brengen & Ophalen
