Please Help ASAP Beovision 4-50 to beosystem 3 setup
This post has 5 Replies | 0 Followers
markr3681
Posts 81
markr3681 Posted: Tue, Sep 30 2014 3:31 PM
Hi would anyone know the steps of setting up a Beovision 4-50 to a beosystem 3? The painters took it off the wall and the manuals are not telling me much :S i've got all the cables, And an the minute ive just got this setup with a sky box so shouldnt be too hard.
Should be easy if someone knows the steps just don't want to get it wrong
thanks everyone
markr3681
Posts 81
markr3681 replied on Thu, Oct 2 2014 10:50 AM
Does anybody know ? ive connected all the cables as the manual says but just wont power up am i missing something :/
Dave Farr
France
Posts 2,283
Dave Farr replied on Thu, Oct 2 2014 11:35 AM
markr3681:
What doesn't power up - the Beovision4_50 or the Beosystem 3?
Have you been prompted for the PIN code?  Is the TV PIN protected or disabled?
Is the mains plug fully connected into the TV?
More info may help formulate an answer for you.
Dave.
markr3681
Posts 81
markr3681 replied on Thu, Oct 2 2014 12:16 PM
Hi dave, The beosystem 3 powers up the green light comes on for 5seconds then turns off,
The beovision 4-50 doesn't power up and yes fully connected. Ive got two 4-50's and my other one even when not connected to a beosystem you can hear the fan turn on when plugged in. Ive asked B&o but even they don't have an answer yet
So for the time being i have a large expensive bit of glass on my wall :'(
Dave Farr
France
Posts 2,283
Dave Farr replied on Thu, Oct 2 2014 12:27 PM
Sue the painters!
Do you know what they did before they took it off the wall?  Sounds as though they've done something it didn't like.  If the BV7 doesn't power up maybe there is an issue with the PSU after disconnection?
Hopefully B&O or your dealer can help.  It's a mystery.
Dave.
markr3681
Posts 81
Dont worry they had an ear full already :@.
Although to be fair they did turn off power then disconnect the cables keep the Tv up right as its a plasma then redone them steps so couldn't of been them
B&o shell be getting back to me but getting info the the store i purchased it off is a nightmare, i waited 7 MONTHS for a beolab 2 i paid for so hopefully wont take as long. I wont be naming the store but was a main b&o store.
i shel update once i hear
Page 1 of 1 (6 items) | RSS
