Apologies if this has been raised before, but I read this on the B&O site regarding the Beo4:-
With Beo4 you have a remote terminal that makes all others unnecessary.Control virtually any external device: DVD, Blu-ray, NAS, digital receivers or Apple TV, or even your fireplace, alarm or curtains. If you want to put it all together in one place, we provide the only remote you need for your entire home."
Has something changed, perhaps on newer Beo4s? I was always led to believe that the Beo4 could only control B&O equipment and not others unless of course use was made of products such as those supplied by Lintronics etc.
The above statement on the site certainly gives me the impression that the Beo4 is all that is required to achieve control of all devices (to me anyway!).
Thanks.
Well partly true, provided you use it with B&O or Lintronic equipment capable of controlling other equipment
ajames: Well partly true, provided you use it with B&O or Lintronic equipment capable of controlling other equipment
Like being "Partly Pregnant" then? Still believe the statement is somewhat disingenuous, misleading or at the very least confusing.
Thanks anyway!
kokomo:Apologies if this has been raised before, but I read this on the B&O site regarding the Beo4:- "A single remote to control your entire home With Beo4 you have a remote terminal that makes all others unnecessary.Control virtually any external device: DVD, Blu-ray, NAS, digital receivers or Apple TV, or even your fireplace, alarm or curtains. If you want to put it all together in one place, we provide the only remote you need for your entire home." Has something changed, perhaps on newer Beo4s? I was always led to believe that the Beo4 could only control B&O equipment and not others unless of course use was made of products such as those supplied by Lintronics etc. The above statement on the site certainly gives me the impression that the Beo4 is all that is required to achieve control of all devices (to me anyway!). Thanks.
Only 'thing' it can't control is your wife/girlfriend/partner 😊
Millemissen:Only 'thing' it can't control is your wife/girlfriend/partner 😊 MM There is a tv - and there is a BV.
BeoNut since '75
