Beoxox RL 35
This post has 4 Replies | 0 Followers
georganic
Posts 11
georganic Posted: Wed, Oct 1 2014 1:14 AM
Just purchased a pair of these on eBay.  One of the speakers has something rattling around inside.  Can't figure out how to get them apart.  Only screws are the 2 plastic ones that hold the straps and the t small screws that hold the speaker wire spring clip block.
Anybody?
georganic
Posts 11
Beovox, not Beoxox
Dillen
Copenhagen / Denmark
Posts 13,191
Dillen replied on Wed, Oct 1 2014 2:37 PM
Remove the straps.
Then carefully prise off the front cloth frame.
It's held in place by a handful of 5cm long pieces of double-sided tape.
Then dismount the woofer to get inside.
You'll probably find a lose ferrite core from one of the filter coils.
georganic
Posts 11
Thank you.  Is that repairable?
Søren Mexico
Mexico City
Posts 6,411
If a coil is loose and wires undamaged, just glue it back where it was before. Use silicone and clean with IPA before gluing
Page 1 of 1 (5 items) | RSS
