BS9000 power on volume settings?
This post has 3 Replies | 0 Followers
amigo
Posts 11
amigo Posted: Sun, Oct 12 2014 9:45 PM
Hi
My BS9000 Start up every time at Volume 34 (its quite high with my speakers) is there anyway i can adjust the power up volume setting ? So i dont need to turn volume down everytime i start the BS9000?
Dave Farr
France
Posts 2,283
Dave Farr replied on Sun, Oct 12 2014 9:58 PM
You should be able to lower the volume with the relevant volume down arrow button, press 'OK' on the panel to accept the level.  You should be prompted by a display saying 'SOUND OK?'.  Press 'OK' again to confirm.
Dave.
amigo
Posts 11
amigo replied on Sun, Oct 12 2014 10:02 PM
Thanks Alot Dave :)
Jeff
USA
Posts 3,793
Silver Member
Jeff replied on Sun, Oct 12 2014 11:43 PM
From the Beo4, set the volume you want, press List until you get A. Setup. Press the OK button in the center of the arrows, then press List until you get S. Store on the Beo4 display. Press OK and it should remember the settings. You can also preset whether you want any bass or treble adjustments or even loudness preset when you turn it on using this approach.
Jeff
Page 1 of 1 (4 items) | RSS
