SLG error 30 and 32 on BS9000 MKII
This post has 4 Replies | 0 Followers
amigo
Posts 11
amigo Posted: Sun, Oct 5 2014 7:46 PM
i got the errror when run test 27 i got SLG error 30 and 32 and now 33 and 41.
Right now the cd tray is stopped at cd 4 and will no pickup any other cd or play the cd. its restart automatic.
How can i fix this problem?
Beobuddy
Utrecht, The Netherlands
Posts 3,972
I would start by cleaning the sensor beneath the sledge. There are 2 white surfaces which aren't  white anymore. Detection fails.
And when you're cleaning, I also would clean the mechanism by removing old hardened grease as far as you can reach.
amigo
Posts 11
amigo replied on Mon, Oct 6 2014 11:20 AM
Hi.
the white sensor , where are they? under the cd laser? i have take the clamper arm off and cleaned the clamper arm and the laser, but no white surfaces. Can you give me a hint?
amigo
Posts 11
amigo replied on Mon, Oct 6 2014 2:53 PM
I have clean all i can see and now its works agian :) .. I only got one error SLG33 when i run from cd6 to cd 1.. but the bs9000 now plays.
Beobuddy
Posts 3,972
Take the bottom plate off. Then the white surfaces are visible under a small circuit board.
Page 1 of 1 (5 items) | RSS
