How best to hook up Pentas (mk1) to receiver without preamp outputs?
This post has 5 Replies | 0 Followers
Esk8mw
Posts 1
Esk8mw Posted: Mon, Feb 8 2016 4:29 AM
I have a pair of Pentas mk1 I'd like to hook up to my receiver, an Onkyo tx-8011 http://www.onkyousa.com/Products/model.php?m=TX-8011&class=Receiver
Right now I am using a headphone jack adapter, 1/4" to 2 female rca  connectors (cheapo cable), and plugging the Pentas into the rca connections using line out on the speakers. This works, but there are two issues. One is there's a loud pop from the speakers when I power on the receiver. Other is that there is fairly loud static in the speakers at all times when powered on, whether or not any sound is coming through.
i don't think the primary problem is with the speakers as I've had them hooked into a beomaster 5500 using line out into the 5500 pre amp jacks and the static and pop were not there.
is there a simple fix here, e.g., connecting these two components differently or using different or better quality cables? The goal is to use the Pentas for my tv, DVD player, CD player etc.
sorry if this is quite basic, I'm a novice. I love the Pentas but would like to avoid buying additional components of possible. Any help greatly appreciated.
Peter Pan
Posts 2,088
Peter Pan replied on Mon, Feb 8 2016 12:32 PM
Hallo Esk8mw
Download manual- Click here.
Premiumverum
Netherlands
Posts 115
Unfortunately your receiver is not the most suitable for connecting active B&O speakers. The hum and buzz you are hearing is a common problem when connecting beolabs to a headphone jack.
What you need is a receiver with a volume controlled preamp out. Looking at the onkyo it should not be difficult to find a similar model with the same kind of inputs for not too high a price with this preamp out.
Or, you could use the beomaster, it has similar inputs to the onkyo (tape, phono)
Earle
Posts 223
Earle replied on Wed, Feb 10 2016 12:33 AM
Check this out...
http://archivedforum2.beoworld.org/forums/t/6401.aspx
I built it to solve this exact problem. The schematics are easy to find online if you have little electronics know-how. There are also commercially available units like it, but they're usually overpriced, especially when you consider the cost of materials. It basically attenuates the speaker output and turns it into line-out (up to 250watts, I believe).
kallasr
Germany
Posts 2,562
kallasr replied on Wed, Feb 10 2016 9:25 AM
http://soundsheavenly.com/line-in-connection/33--attenuator-.html?search_query=attenuator&results=6
Would this do the job?
Ralf
Earle
Posts 223
Earle replied on Wed, Feb 10 2016 4:47 PM
Yup, that would do it. It's one of those "commercially available" units I mentioned in my earlier post. It's a excellent/quick solution if soldering isn't your thing. Opportunity cost, I guess. For me, it was a case of loving DIY, and generally being a cheap-person (cost of parts was appx $10USD)
Big Smile
Page 1 of 1 (6 items) | RSS
