I Have a Beogram 4500 record player. It works fine with my amplifier and speakers.
now I want to use it with a Sonos amplifier and plugged it to the audio in - but no sound came out.
As far as I can see on the net, there is a build in IRAA amplifier in the beogram, but some says it might be turned off. Could this be the problem, and how do I turn it on again?
Any help would be appreciated.
To which amps was it connected before??
Thanks for the quick reply 😊
a 20 year old Teac amplifier with a phono in.
thanks for the quick reply!
it was a 20 years old TEAC amp with a "phono in"
Sorry for the duplicats 😃
and "RIAA" of course
If you are using a DIN-4xRCA adapter, make sure you ar eusing the correct two RCAs (the outputs).
