I have a unit from England I have restored. The main tuner only goes to 104. After restoration all the FM stations are off a little. Any ideas why? Since the unit did not work when I got it. I do not know if this is just how this tuner works?
Should the title read Beomaster 1200 ?Given that it should, if the whole frequency range is slightly off, the most probable cause is that thefrontpanel has been taken off during service and the dial pointer not put back exactly where it was.Losen the two small screws holding the clear piece of plastic that binds the string to the backside of thetop rail of the dial pointer and slide the whole pointer on its string to the correct position, then tighten again.
