Sir i want to ask you one question about this system...to be more specific,when you turn up or turn down volumen from remote control is it some sound come out...not the volume or the music sound...same different sound...to be more specific some zzz sound.... i dont know what is the problem?!Does someone knows???
l'm looking forward to hearing from you!
I'm not sure about the Beomaster 5500, but my Beomaster 5000 doesn't make any sound when you adjust the volume.
omg.....
Thanks man....
Noisy voltage caused by bad power supply filtering is reaching the volumecontrol chip.Replace the small electrolytic capacitors in the voltage regulator area.
Please choose a more saying thread title.
Mr.Martin do you know is it possible to be replace whit no problem....do u know how much is that replace (that part)how is it look that part...pls help
Im from Macedonia and we dont have official stor for Bang & olufsen...
If you can help me i will be thankfull
