Mounting device for Beolink infrared eyes
This post has 3 Replies | 0 Followers
Manbearpig
Posts 908
Manbearpig Posted: Mon, Nov 10 2014 2:56 PM
Dear members,
I have seen some sort of table stands or table holders for the Beolink aluminum infrared eyes:
http://www.ebay.de/itm/like/281488024876?clk_rvr_id=728494606977&crlp=1_260601&mt_id=637&mid=503295&sdc_id=1415631285z225148z40073b0a1960zz&fitem=281488024876&linkin_id=8088399&crdt=0&sortbid=8
Have you made any experiences with one of those? Will such a device also work with the LCS 7000? Or does the LCS 7000 need to be wall mounted?
Greetings,
Kai, who does not know the seller or has done any business with him.
Millemissen
Flensborg, Denmark
Posts 14,680
There is not much to it!
A heavy piece of aluminium with a place for the ir-eye and a hole for the cable.
http://www.youtube.com/watch?v=WzoH3-R4qFE&feature=youtube_gdata_player
I have had one (in black) for years - I like it.
I don't remember how much I did pay - but not that much!
Try googling for 'BOSSCOM IR Eye Stand' to see if you can find another seller.
It is one of the few Bosscom items, that I can recommend.
Manbearpig
Posts 908
Thanks Millemissen. How is the IR eye fixated on the holder? Does it easily come off when pulling on it? Since the LCS 7000 is magnetic there is a high risk of pulling the LCS 7000 out of the holder when taking the Beolink 7000 out of the charger I guess.
Cheers,
Kai
Millemissen
Flensborg, Denmark
Posts 14,680
The 'normal' ir-eye fit nicely into it, and can -relatively - easy be removed.
I have no idea if that would be different with the LCS7000, sorry.
Page 1 of 1 (4 items) | RSS
