BeoVision 11 and SCART
ReneB
Posts 64
ReneB Posted: Sun, Nov 9 2014 3:55 PM
couldn't find it here on the forum, hence:
what's the most convenient way to (occasionally!!) connect SCART-only video equipment to a SCART-less BeoVision 11 ?
btw: the AV-input is listed as "mini AV". Is this a nine-pin "mini DIN" ? would this be the one: (couldn't find much more than this one!!)
http://www.alibaba.com/product-detail/Scart-to-Mini-Din-Cable_2004055808.html
or is it just what we used to call an S-Video connection?
Rene
BeoLignage
Sweden
Posts 207
Hi Rene,
have a look at link should be the same as for the V1 which is discussed in that thread. I think the answers you'r after are in there.
You should buy the adapter from your dealer, I tried another one prior to asking the dealer, it turned out not to fit. Also the B&O adapter was less than €20
Good luck
//Goran
ReneB
Posts 64
ReneB replied on Sun, Nov 9 2014 5:44 PM
thanks Goran, I missed that one since I searched for SCART and BeoVision (11 / Avant)
so the short answer is "an 18 Euro scart-to-9-pin-DIN" sold by B&O dealers works perfectly to get analog AV into not only an BeoPlay V1 but also the BV11" (and I guess the new Avant).
So no need to (re)consider a SCART-to-HDMI converter ..... ? ( I read some disappointing stories about that obvious alternative solution).
Rene
Millemissen
Flensborg, Denmark
Posts 14,680
Item number 6271217 for the scart male adapter (2 m) - 6271215 for the female (0.75 m).
Page 1 of 1 (4 items) | RSS
