Hi I have a beo 4500 and just noticed the bulb isn’t coming on ,it’s the light that stays on for about 5 seconds.would any one have any idea how you change blown bulbs?thank you in advance
Take off the black rear plastic cover (two screws at the back) and you can gain access.New lamps here: https://www.beoparts-shop.com/
Thank you Dillen will give it a go
