Hi everyone
can someone let me know where to purchase replacement belts for my beocenter 7007
many thanks
andytga: Hi everyone can someone let me know where to purchase replacement belts for my beocenter 7007 many thanks
First call for any 'correct' belts is member 'Dillen' - Martin. Send him a PM. If he hasn't got the right ones, he'll point you in the direction of the correct source/seller. so called generic belts just don't cut it most of the time or the profiles are incorrect.
If Martin reads this - Martin, could you publish a list of all of the belts/machines you can cover for this? If we have it as reference, maybe we wouldn't keep getting the same qustion asked about belts.
Dave.
Sorry I asked Dave !!!!
andytga: Sorry I asked Dave !!!!
I wasn't having a dig at you - sorry if it seemed so. We get a lot of questions related to new belts for old machines and Martin 'dillen' carries some but not others. It would help us all if we knew which ones and had a reference document to refer to in the FAQ section. It helps everybody then.
I hope you find the correct belts and get your machine up-to-speed.
