Hello,
I have a beautiful black Sd Beovision 5 on a motorised stand. I've owned it for a couple of years and love it. To be honest I'm pretty happy with the picture quality but I've damaged the screen by rubbing with a microfibre cloth at a couple of dirty spots. The picture when on isn't affected but it sort of upsets me to see it like that!
Anyway, I have been thinking of BV11 but I'm not really taken with any of the stand arrangements. I might well go down that route but I think it's still overpriced even at the new bargain level. priorities and all that!
To get to the point, is it worth me upgrading to the HD BV5? I'm assuming the panel is newer so maybe better in that respect. I understand connectivity is limited but how does the dvi connection work with for example a Sky HD box? Would I notice a difference? I currently have a DVD1 connected as well as a Wii which I use for Netflix (new series of Lilyhammer just added!)
Thanks for any suggestions, apart from the inevitable ones telling me to buy suchandsuch instead! It's a BV5HD or nothing at the moment I'm afraid!
Simon
Thanks Lawrence! To be honest I'm not too bothered by the HDness as I'm very happy with the picture quality of my current BV5. I wondered if sky hd would be any better and how involved it is to get it to work properly. More to the point I was also wondering if the panel itself was any better. I had a chat with a B&O shop manager who said he finds it hard to believe that I've damaged the coating on my screen just by wiping with a microfibre cloth but I have and it annoys me! If I could get another SD BV5 cheap I'd certainly consider that option!
p.s I think a BV9 would be overkill in my little cottage!
simon8201:p.s I think a BV9 would be overkill in my little cottage!
4 beolab 5, beolab 9, beolab 10, beolab 5000, beolab 8000 mk2, beolab 6002, beolab 3500, beovision 7 55 mk2, 2 beovision 11 46 mk4, beotime, beosound ouverture, beosound essence, beoplay A8, beomaster 900 RG de luxe and the collection continues...
