Beovision 7 antenna connection
leosgonewild
Helsinki, Finland
Posts 2,373
leosgonewild Posted: Fri, Nov 28 2014 11:23 AM
I recently purchased a used Beovision 7-32. I am searching channels through the regular antenna connection, but no channels are found.
Is there a setting in some menu that could have been turned of by the previous owner?
Barry Santini
New York
Posts 543
OTA antenna should be attached to Antenna 2
Rob - Danish AV
Melbourne
Posts 376
Are you searching analog channels? in Australia the analog signal is switched off and the TV needs a digital tuner. Some 7-32 don't have a digital tuner at all, but can always connect a set top box..
leosgonewild
Helsinki, Finland
Posts 2,373
I changed the range settings in the tv-tuner menu. Problem solved :)
Thanks for input, guys :)
Mark
London
Posts 1,063
Mark replied on Sat, Nov 29 2014 5:52 PM
interesting can you let me know what you did .... on Freeview (built-in) for some reason I can only pick up about 80% of the channels that are available and I know it's not the aerial as my previous visual system picked up all available channels.
leosgonewild
Helsinki, Finland
Posts 2,373
with the tv on, you press 0+0+menu+menu+go.
then choose tv-tuner.
Then there are four places where you can change the numbers, two are called "low, and two are called "high".
The two "low" I put to 49. (press "0" and it will change it automatically to the lowest posible which is around 49)
The two "high" I put to 860. (press "999" and it will change to the highest which is around 860)
Please write down the current settings before change them, in case you need to revert them.
(Sorry that I don´t have the exact names of the places you should change the numbers, but I don´t have the tv-set avaliable to chack atm, If you need more assistance just tell me, and I will check it later)
Keep me updated if it fixes you problem :)
Page 1 of 1 (6 items) | RSS
