I currently have the BS9000 connected to a headphone amp/dac via coax only, and removed the speakers from the configuration. In one of the BS powerlink connectors I have attached a blank, and i also set the BS9000 to option 1. While i can turn on the BS9000 via the Beo4 remote, I have no other remote functionality (change disks, volume, turn it off). I also tried option 2 on the BS, to no avail.
Any options, or is it the case that the BS9000 remote will only work with speakers connected to it?
BV11-55, BS9000, BL1, BL19, Transmitter 1, Beo4, Beocom 6000, BeoTalk1 200, Sennheiser HD600, McIntosh MHA100
