Hello,
Is it safe to believe that the color coding is the same for the cable coming out of the MCL2 IR transceiver as for the later "puck" transceiver? I searched through the manuals on site but without luck in finding the "pinout"
First a picture showing the MCL2
and then the puck (it has yellow and grey as well but they are for the buttons)
it is recommended to switch green and white if the transceiver is left in sub zero temperatures
I guess it makes sense to cut power +5V and IR signal wire to not get noise in from a non powered reciever
thankful if someone can confirm anyway
//Goran
