I have a beogram turntable and the platter the record sits on sit up one end higher then the other and makes a scraping sound when the turntable is being used.........any ideas ?
Which Beogram? The first thing to look at are the transit screws. Sometimes however the springs can need adjusting - how to do it rather depends on the particular Beogram.
Peter
I have a beogram 2000
