Has anybody noticed the same problems as I have when trying to push the update button on the converters web page...
Message : Error authenticating with BeoPortal
The reason I'm trying to force an update in the converter: I'm on version 1.3.0.0, but the new Beoremote 2 mentioned 'there is no support for this application, it could be a software update is needed'.
And another strange behavior of the converter, date is still at 2010-NOV-15
"Believe nothing you read and only half of what you see, let your ears tell you the truth."
Changed the unit this morning to another one, all works well now again.
A fault in the NIC according to my dealer? He changed the converter without additional cost.
