I currently own a Beosound/Beomaster 5 and would like to set it up so it works with my Beogram 3300. I have the pre-amp cable needed in order for the Beogram 3300 to work with the newer B&O systems and I also have a U-control UCA222 Behringer, which I was told would enable me to use the Beogram through the Beomaster. However when I attempt to find and/or play the Beogram 3300 through the Beosound 5, It doesn't display the system. I keep trying to locate it under the A.Aux mode, however I can't find it. Has anyone else had difficulties setting up a Beogram product with their Beosound 5? Any help would be appreciated!
The BG 3300 has no preamp
Hey I meant to say that I had the pre-amp cable but I am still unable to get it to work with the Beomaster 5
I am not familiar wtih the Beosound 5, someone else must help you, just be patient
