Time to replace the batteries on the Beotime and I removed the end cap with the key and took the battery tray out . As I realised I had no batteries I put the tray back in without any . Now it's difficult to get the tray out. Anybody else found this or do I just lever it out without doing any damage ?
thanks
Beo Century ,Beoplay V1, Beocenter 6, Ex-Beolit 12, Beotime , A8. Beolit 15 , Form 2i , Beolab 2000, Beoplay A3.Beosound 1
BeoGreg:It was hard to push it back and to pull it out also !
4 beolab 5, beolab 9, beolab 10, beolab 5000, beolab 8000 mk2, beolab 6002, beolab 3500, beovision 7 55 mk2, 2 beovision 11 46 mk4, beotime, beosound ouverture, beosound essence, beoplay A8, beomaster 900 RG de luxe and the collection continues...
Reassuring then, as it seems difficult without the batteries. It might be worth a bit of pressure getting it out ?
Its a tight fit for sure. I found it harder to get back in than out.
Guess you will just have to tease it out. When inserting the battery pack push gently until it resists then pull it back a little bit and turn it and try again.
Yes. I seriously thought I was going to break the battery holder pushing it in but it was a bit easier when I decoded the orientation diagram .
