Masterlink Linkroom L.Option 4 and V.Option 6
georgey007
Posts 74
georgey007 Posted: Sun, Feb 22 2015 7:35 AM
Hi
I have a problem which I couldn't solve by finding it on the forum.
I have a beolink aktiv and a bv8-40 in the same room, it's a linkroom.
I set up the beolink in option 4 and the bv8 in option 6
Now when I start the TV everything is fine the Aktiv isn't power up, but if i press link an for example radio the tv and the beolink are powering up???
shouldn't by pressing link the ir codes only control the beolink aktiv
should i try a different setting ?
regards George
stefan
200 miles from Struer
Posts 2,920
stefan replied on Sun, Feb 22 2015 10:11 AM
Set BV to V.OPT 5 and  BL active L.OPT 4 or both to OPT 5.
Stefan
georgey007
Posts 74
Thanks will try
Page 1 of 1 (3 items) | RSS
