I guess this has been asked before, please accept my apologies in advance.
I have a pair of Beovox 5000 flat panel wall speakers running off a MCL small amp with standard speaker wire supplied by the nice people at Sounds Heavenly. No issues, happy camper, all sounds great.
However, I have taken the plunge into a Beomater 8000 which is being serviced/re-built as we speak.
My question is...
is there any need to invest in different speaker wire?, I always feel the black and grey seems a tad small but I dont want to be a fool and buy alternative wire if there really is no noticeable difference in the sound. I have moved on from the crazy hifi marketing of speaker wire and power cords since my introduction to B&O, but I was just wondering if there is a superior wire recommended by B&O fans.
Many thanks
Any cable you buy from Steve at Sounds Heavenly is more than enough for B&O applications. Steve understands the needs of his customers and supplies first rate products. I wouldn't go to anyone else. I don't believe you will notice any difference with alternatives.
Dave.
Absolutely agree with this. As Dave mentions, Steve's products are very good and I couldn't recommend the service highly enough,
Ben
The original speaker cables for Beovox speaker are 0.75 square mm. the ones for active speakers are even smaller, I have run my BL 8000 with 3 meter long 0.5 square mm cables from an Onkyo receiver without problems. As the wild Leo says any good copper cable will do. Dont buy into snake oil.
Just as I thought,
many thanks,
and I agree Sounds Heavenly have been great, supplied all my connections for turntable and ipod.
