Greetings all,
I am urgently looking for the small decking plate for my BG4000 table project - can anyone supply one?
I would also consider a BG4002 one, which would then have to be modified!
Any offers ??????????
Thanks - ALF
Just to clarify in case there is some cofusion:
It is the small plate that sits in the top right-hd corner above the control panel.
ALF
Anyone in the great widewide beoworld ????????????
Cheers
ALF.
