Hi all,
I have recently been given one of these systems by my parents (who owned it from new), however it has been stuck in a loft for over a decade, thus meaning that it's not exactly in prime condition. After opening the box I saw the aftermath of an attempted fix by a family friend, leading to a panel being put on upside down. How would I go about removing this panel and fixing it back on correctly? Here are some pictures.
[/URL]
Furthermore, a B&O specialist said that there was a problem with the "relay" in the system. What is this?
Thanks in advance. Can't wait to get to work.
-WhatsGoingOn
Check underneath the glasspanel at the left side. You'll see a philips screw which needs to be removed. After removing slide the panel to the right and it will come loose. I have some glasspanels left if you're interested. The lower which is upside down seems to broken?
Relay? Probably the mute?
Brengen & Ophalen
Taped down? So probably loose from its glueing from plastic frame. Be aware, dont drop it.
