Hello All
I have a BV7 in my main room and some other link rooms that i Play from the audio master.
Is it possible to turn down the volume of a link room or turn off a link room TV while in another link room or the main room?
I have a beo4 and Beo6.
Cheers All
Eclipse 65V1-32Beosound M5Essence MK2BLI
Ah, you know... A little B&O here, a little there
Hi thank you.
I suspected as much and I know about the all power off.
I cannot bring myself to buy a ML gateway with Beolink gateway so close. I cannot bring myself to buy a Beolink gateway until I know at least a little about what it can do.
same story different products
