http://www.cesweb.org/Press/Press-Events-Schedule/2015/Bang-Olufsen-2015-CES-Press-Reception-INVITATI-(7).aspx
What can we expect from BeoPlay?
I guess that for B&O the new concept will be the Encore Moment.
I wonder if you mean: the BeoSound Moment?
Beoworld member 'Hiort' has an invitation - I am sure he will tell us, what happens at that reception.
Oups
Yes, thank you for correcting my mistake.
Millemissen:I wonder if you mean: the BeoSound Moment? Beoworld member 'Hiort' has an invitation - I am sure he will tell us, what happens at that reception. MM There is a tv - and there is a BV.
Livingroom: BL3, BL11, BV11-46 Kitchen: Beosound 1 GVA, Beocom 2 Bathroom: M3 Homeoffice: M3, Beocom 2 Library: Beosound Emerge, Beocom 6000 Bedroom: M5, Essence remote Travel: Beoplay E8 2.0, Beoplay EQ, Beoplay Earset
Hi there
what would be great for most of us is to understand what Netlink can deliver.
there are loads of possibilities but no announcements about what might happen with it. Is it backwards compatible?
Some sort of vision would be great
have a great time I am very jealous :)
Eclipse 65V1-32Beosound M5Essence MK2BLI
NetLink has been working between the newer BV's for a while already.
'backwards compatible' - yes, with the NL/ML Converter.
For how the BS Moment integrates into NL, we will (still) have to wait a couple of days.
Hopefully they will give some information about this too, when the Moment is presented at the CES.
Seanie_230:Hi therewhat would be great for most of us is to understand what Netlink can deliver.there are loads of possibilities but no announcements about what might happen with it. Is it backwards compatible? Some sort of vision would be greathave a great time I am very jealous :)Beovision 7 MKIV (Blu Ray) Beolab 9 Beolab 6000 Beo 4 Beocenter 9300 Apple TV SKY HD Optoma HD65 Projector Lintronic TT455-RT-238 Beovision 3 MKII
Any news yet??? Can't wait!!!
Beoworld app with direct photo upload and emoticons.
...and now a short teaser movie on Bang&Olufsen Facebook wall! :)
It shows someone walking between rooms, hopefully hinting that the new system will have multi-room capability or that B&O customers generally live in a house with more than one room!
...but there is also a "speaker" of some kind on 0:06 - is that Beolab 18 with black grille?
OK... looks like the beginning of the full video, in which she picks up a tablet/controller, sits on a couch and chooses some music. Operation of the device will be smooth and voluptuous...
There is one today also, in just a few hours...
http://www.cesweb.org/Press/Press-Events-Schedule/2015/Bang-Olufsen-2015-CES-Press-Reception-INVITATION-O.aspx
Edit function is not working, just get spinning wheel, should have said in two hours in previous post.
Razlaw: Edit function is not working, just get spinning wheel, should have said in two hours in previous post.
I have had that problem quite some time -- caused I think by my upgrade to Yosemite and / or its associated Safari --- and I did not think to test it under FireFox !
BeoNut since '75
elephant: Razlaw: Edit function is not working, just get spinning wheel, should have said in two hours in previous post. I have had that problem quite some time -- caused I think by my upgrade to Yosemite and / or its associated Safari --- and I did not think to test it under FireFox !
The 'More' drop down window no longer works on my iPad since the last OS upgrade.
Graham
