Beolab 7.2 Distortion
This post has 9 Replies | 1 Follower
diggs2701
Miami
Posts 29
diggs2701 Posted: Wed, Aug 9 2017 11:53 PM
Hello,
I just hooked up my Beolab 7.2 to my beosystem 3 as a center channel and I'm getting distortion/feedback with no volume. I made sure to use the MK3 powerlnk cables. This is hooked up to a bs3/beovision 4-65 combo. Any ideas what it could be? Thanks,
Diggs
diggs2701
Miami
Posts 29
diggs2701 replied on Thu, Aug 10 2017 2:02 PM
Update: I hooked up the beolab 7.2 speaker to the BeoSound 4 directly and had no distortion. I'm guessing it has something to do with the beosystem 3? I previously had the beolab 4000's hooked up to center channel on the beosystem 3 and had no distortion. Any thoughts? Thanks.
diggs2701
Miami
Posts 29
diggs2701 replied on Thu, Aug 10 2017 10:56 PM
Another update: it seems to make a noise/feedback with every volume click of the remote. I'm going to reset system over the weekend and see if that helps.
L1NO
Posts 250
L1NO replied on Fri, Aug 11 2017 8:35 AM
That is usually a ground issue. Check the cable's and connections.
diggs2701
Miami
Posts 29
diggs2701 replied on Fri, Aug 11 2017 4:04 PM
Thanks L1NO! Do you think it is a ground issue with the Beosystem 3? Or maybe the surge protector?
9 LEE
Eastbourne, UK
Posts 7,218
9 LEE replied on Fri, Aug 11 2017 8:10 PM
diggs2701:
Cable issue I think..  Odd that it doesn't show itself when you connect to the BeoSound 4 though...
Try a Mk2 cable, with full shielding. It may be interference?
diggs2701
Miami
Posts 29
diggs2701 replied on Mon, Aug 14 2017 3:14 PM
I re wired the system and the volume clicking has now disappeared. The center channel still has the distortion problem and I tried multiple cables. Could it be the power cable? It is very strange that it works perfectly when hooked up to beosound 4 directly...
diggs2701
Miami
Posts 29
diggs2701 replied on Wed, Aug 23 2017 2:17 PM
Any thoughts on this? Should I have a B&O person come out? They charge 250 an hr. Thanks.
L1NO
Posts 250
L1NO replied on Wed, Aug 23 2017 4:46 PM
diggs2701:
Ground-cable issue. Re-check cables and make sure they are the right type, not damaged and fit well. None of BangOlufsen gear should be grounded, but other devices trough HDMI (any connector) can ground the system making a ground loop.
diggs2701
Miami
Posts 29
diggs2701 replied on Mon, Oct 30 2017 2:30 PM
It turns out that a fan in a separate room wasn't fully grounded. Once that was fixed no distortion. I almost went through 5 sets of different cables! Thanks.
Page 1 of 1 (10 items) | RSS
