Foxtel iQ3
This post has 3 Replies | 0 Followers
Aussie Michael
Melbourne, AU
Posts 3,730
Aussie Michael Posted: Mon, Sep 14 2015 10:06 AM
Hi
Do any of the Aussies on the forum use the Foxtel iQ3?
If so, how have they found the integration with the beovision?
I haven't had any major issues, the only issue i have is that my foxtel box will not power on with the my buttons on my Beo Remote One.
It turns off no problem, just the command to turn it on, which i thought was the same as off.
Was wondering if any others have had any issues?
Thanks in advance
Michael.
Aussie Michael
Melbourne, AU
Posts 3,730
I have found the answer so i believe
Source List > Foxtel> Enable from standby
Thought i would fill the Aussies in in case you were wondering
beolion
Posts 485
beolion replied on Wed, Sep 16 2015 12:30 PM
Thanks. Still using the Optus Fetch TV but am considering Foxtel.
Aussie Michael
Melbourne, AU
Posts 3,730
beolion:
👍🏻🇦🇺 go with whatever suits you more. If you like HBO Foxtel or presto may suit. Otherwise maybe try Netflix
Page 1 of 1 (4 items) | RSS
