Beovision 7 and PS4 connection.
This post has 5 Replies | 2 Followers
lj20
Posts 2
lj20 Posted: Sun, Jul 6 2014 8:16 PM
I have a Beovision7 that was upgraded for HDTV some time ago. Got a PS4 for the kids and guess what? How do I connect? I have tried connecting the lead from the PS4 into the HDTV adaptor on the rear of the TV but cannot find the PS4 signal. I also have a Sky plus box.
Any views help on this would be much appreciated as I am starting to fear that what's needed is a new TV!!!! I am getting much aggro form the kids also. Help please!!!
The Beonic Man
Bristol
Posts 812
What type of adapter are you using on the back? I am assuming you have a Mk1 or Mk 2 BV7 with just 1 DVI socket. This means you can only connect 1 HD cable unless you use a splitter. Check out the Atlona website as they should have something suitable. If the connections are all fine and the adaptor types correct then I am not sure what to suggest. Can someone from B&O come out to advise further?
http://www.atlona.com/Atlona-1x4-HDMI-Distribution-Amplifier-HDMI-with-3D-Support.html
B&O products are V1-32, BS2, H95, E8 and an Essence remote.
11-46 now replaced with Sony A90J 65”, Sony HT-A9, Sony UBP-X800M2 and Sony SRS-NS7.
lj20
Posts 2
lj20 replied on Mon, Jul 7 2014 7:39 AM
Correct. I only have one DV1socket and use an adaptor to connect my Sky satellite box to the TV. I have tried connecting the PS4 directly to this adapter ( removing the Sky satellite box) and also connecting into the HDMI portal through the Sky satellite box. I cannot find the PS4 signal doing either. I may be not looking at the correct page using the B&O TV control. Where should I be looking for the signal / what settings should I set up?
The Beonic Man
Bristol
Posts 812
Can you phone your dealer for further support? In the meantime someone else might chime in but it could be all sorts of reasons. Not very helpful I know.
MartinW
Posts 389
MartinW replied on Mon, Jul 7 2014 10:00 PM
Hi, your DVI connection will only support HD to 720p, not full HD at 1080p. If you can connect the PS4 to a full HD tv and get into the display settings, you should be able to change the display settings to 720p. You will also need a separate audio cable from the PS4 to the TV in the same way you did with Sky. And your Sky box will need to run off something other than HDMI - such as Scart if the Sky box has one.
leosgonewild
Helsinki, Finland
Posts 2,373
Did you ever sort this out? I am planning on doing the same.
Page 1 of 1 (6 items) | RSS
