Really annoying change to iplayer on my BV 11 -it must have been done in the last day or so.
You can no longer access radio iplayer via the Smart functions on the TV.
It looks as though it may not be B&O's fault, since the same change has just been implemented on my Panasonic Blu-Ray recorder.
Is there any solution to this problem? Who should we complain to?
I do have apple TV and can use iPad to mirror radio iplayer through to my system - but this is much less convenient - and I still get drop-outs.
