Hello
I have recently purchased a Beogram 1001 Type 5101 from eBay to accompany my Beomaster 900M. However when plugging the two together I'm not hearing any output, a little digging around I'm learning the I'll need to source an external RIAA pre-amp as neither the Beogram or Beomaster has one fitted as standard.
Does this sound reasonable?
Many thanks
I think the amp has an RIAA in it.
beo3000: I think the amp has an RIAA in it.
Some of the latest versions of Beomaster 900 had the RIAA installed from factory.The majority hadn't.
in that case
http://www.ebay.co.uk/itm/PHONO-PREAMP-STEREO-Turntable-RIAA-PREAMPLIFIER-/152495078051?hash=item23816a3aa3:g:TMIAAOSwXYtY4SFC
here's a cheap one, I would not recomend an expnsise one I had one once it caused issues my cheap one works fine
