Hi
please forgive me for not knowing the names of the parts. Complete newbie. Fixed a few problems already but can anyone tell me where the part sitting on top of the white cog goes? Pretty sure it’s not supposed to be on the top. Thanks. Trying to put a picture in from media but not working at present. Will keep trying.
I can't add the image which I have saved in the media section. It says nothing to list. Are you able to view my image from the media section?
The white end goes under the (teflon on metal) friction plate on top of the deck (under the platter).
I can't imagine how it escaped,but if you remove the white gear wheel you'll see where it slots into the chassis.
Make sure the tiny wire spring on the red relay arm does'nt fly off either,as they are a real trial to find after they shoot past your ear!
Nick
Thank you. I do not know the names of any of the parts and so can't work out what parts you are referring to. Can you describe which are which? Thanks
Thank you. Will see if I can work out how to remove it.
