Hello!I'm thinking about upgrading my home with a few B&O compatible switches to use the light funktion given by the remotes Beo4/5/6 and RM one;last forum entrys are long ago - 2012There are solutions by lutron rania or bosscom which provide a simple change from my now installed switches without much work.But: nowadays ones bulbs are already led type - so they are only some watts - the specs say that the dimmers need at least 40watt power consumtion.And: I don't know if these products are compatible with cross connection (2 or 3 switches).I also have one installation with push-buttons (4 push-buttons control one lamp).Do you have any experience on those "old-fashioned" Rania or bosscom dimmers/switches usind them with new led bulbs or led lamps? With cross connection?Many thanks
Elmar
