I have a LX6000 which goes into standby mode at random times... I had a LX5500 which had the same problem, but can't remember how i fixed it... any thoughts? the TV is still in excellent condition and seems a shame to throw it out.
This could be due to something triggering the protection system,that is designed to set the tv to standby in case of a fault.The age of the set of course means that tired capacitors are probably ready for replacement too.
Several "usual suspect" soldered connections will need attention.
Well worth repair ineed,but only attempt it if you are sure what you are doing.It can be dangerous in there!
