Hi Guys,
I have a minor problem with connecting a DVD player to the BeoVision.
Currently I am using a BeoLink 1000 terminal to control the LX 2800
I did found a code which could work but it did not, I got in AUX 2. menu though...
the code went like pressing: shift + v.tape + tv + 2
and then it should work
Hopelijk weet iemand wat het probleem kan zijn om wel beeld van de DVD speler te krijgen :)
Bedankt alvast,
Miho
Hoop dat dit werkt..
